Solid Wood Machining
S three S
4/10/26
Kirby Cole Member
I have a small shop and need to be able to S3S. What is the fastest, easiest way to accomplish this. I sell white oak lumber so a will be milling just white oak .
4/11/26       #2: S three S ...
Dustin Orth  Member
You need a straight line ripsaw and either a double sided planer or a molder to do it efficiently. It depends on how much quantity you are going to run. Just a little bit, those machines aren't worth it.
4/12/26       #3: S three S ...
Kirby Cole Member
Thanks, but can’t do that right now.
4/14/26       #4: S three S ...
Explain how you are doing it now, and where you would like to see improvements.
4/14/26       #5: S three S ...
Allen Chalifoux
I'd be interested in how your currently doing it now too and what your volumes are. Allen
4/14/26       #6: S three S ...
"Can't do it now" indicates a reluctance to consider all your options.
You have been given good suggestions, but are not interested in a dialogue.
Did one take too large a bite, one wonders....
4/14/26       #7: S three S ...
I also wonder if this is a predicament inquiry, or just looking for improvement question.
Getting in over our heads is what got most of us to where we are. So if that's the case, can't slight him there.
4/14/26       #8: S three S ...
Karl - Yes, you are right. I bit off more than I could chew more than once. Sweat and thinking smart kept me out of trouble.
I guess the difference is do you learn to take appropriate sized bites, or do you find ways to chew more efficiently?
4/14/26       #9: S three S ...
Dustin Orth  Member
Im willing to give advice from learning over the last 40 years, if someone doesn't want to listen, that's their choice.
4/15/26       #10: S three S ...
Hopefully both David.
4/29/26       #11: S three S ...
BH Davis  Member
Without the relatively costly mass production machinery your only option is probably what you are doing now. That is, face joint one side, then edge joint one edge and then run for thickness through the planer.
If you are stuck with that then the only upgrade in speed you can make is adding a power feeder to the jointer for the face jointing step. This is commonly done. You might even be able to orient the feeder for the edge jointing step but that is more complicated.
And for those of you coming down on this person for not being willing to consider straight line rip saws etc. I will add that in my career I saw two recessions. Late 80's and late 2000's. In both cases the people left standing were the shops with little or no debt.
5/2/26       #12: S three S ...
Not coming down on him for anything other than a lack of information.
He asked for fastest and easiest. Then Dustin gave him the exact answer.
We weren't given anything to work with. Budget, space, or power restrictions
5/3/26       #13: S three S ...
Well the straight line rip portion can be done with a track saw and a long track. Not going to be as quick as a SR saw but substantially cheaper.
5/3/26       #14: S three S ...
Dustin Orth
It all depends on labor vs machine cost. Track saws can do the job at a much higher labor rate. Straight line rip saw can cruise thru material but at a higher initial investment but labor cost is way lower.
