WOODWEB's Adhesives Forum - Message
  Find Wood, Suppliers & Get Price Quotes FREE!
Colonial Saw
Adhesives &
Fasteners
Adhesives
Gluing &
Laminating
Rockler Woodworking and Hardware
Roger Shaw and Associates
Rose Machinery
Routech
RouterCAD
Royce Ayr Cutting Tools
RT Machine Co.
Sand-Rite Manufacturing
Sandman Products
Sawmill and Woodlot Magazine
Schultz Forming Products
SCM Group USA, Inc.
SCM Group
SCM
Sears Trostel Lumber Co.
Shomaker Lumber Company
ShopBot
SII Dry Kilns
Silvaris
Simantech
Single Source Cabinet Supplies
SIS Machinery
SK-USA
SketchList
SlipCon USA, Inc.
SnapDragon Associates, LLC
SNX Technologies
South State Machinery
Southeast Tool, Inc.
Sovereign Machine, Inc.
North Pacific Lumber
Northstate Hardwoods
Nyle Dry Kiln Systems
O'Shea Lumber Company
Omnitech Systems
Onsrud Cutter
Open the Door Products
Opti-Sand
Original Saw Company
Osborne Wood Products
Paragon Enterprises
Peninsula Hardwoods
Penn Sylvan International
People Logic Software Corp.
Pinske Edge
Pioneer Lumber Company
Pioneer Millworks
Plogic Solutions Ltd.
Pond Cove Paint
Porter-Cable
Precision Drive Systems
Premium Specialty Hardwoods
Prime Estimating and Software Services, LLC
Primo Woodworking Machinery
Pro.Woodworker.com
Pro100
Professional Hardware & Supply Co.
Professional Machinery Group
PYTHA
Quality VAKuum Products, Inc.
Quick Machinery Company
Quickscrews International Corporation
QuickScribe
QuikDrawers
R&R Drummond, Inc.
R.A.W.
R.D. Billhofer Company
Rangate
Rawles-Aden Lumber Corp.
RazorGage
Rex Lumber Company
Riethmiller Lumber
Ritter Manufacturing Inc.
 Home » Forums » Adhesives » Message
  • A personal "member history" that displays your posts at WOODWEB
  • Your forms at WOODWEB will be filled in automatically
  • Create your personal "My Favorites" page
  • Numerous automatic notification options
  • Learn more about WOODWEB Member benefits ...
    Post Response | Notify Me Of New Messages | A Note About Viruses | Read Forum & Exchange Guidelines | View Most Recent Response
    Review Knowledge Base articles related to WOODWEB's Adhesive Forum
    Adhering Acrylic Sheet to MDF/Melamine Substrate
    7/7
    Jeremy
    Looking for help/input in laminating 3/16" or 1/4" thick decorative acrylic sheet to a suitable substrate (5/8" thk MDF? Melamine?) for the purposes of cabinet door construction, room dividers, tradeshow display dividers, etc. Trying to minimize cost by laminating acrylic to one surface of substrate versus both sides. I know this goes against the rules of a "balanced constructed" panel. Has anyone had luck with doing something like this? Any suggestion of type of adhesive or alternative substrate to minimize/eliminate warp, would be appreciated.
    Thanks,
    Jeremy
    7/7       #2: Adhering Acrylic Sheet to MDF/Melam ...
    Maple Dave
    Jeremy,
    I have had good luck in bonding wood to acrylic sheeting using cyanoacrylate (super) glue. The glue hardens very quickly once it hits the plastic so pre-alignment is key.
    I have done this a few times laminating thin strips of wood to translucent acrylic door panels for a divided light look and have not had any problems since I first did this about 8 years ago.
    One consideration is that the CA glue will cause the plastic to cloud. This doesn't matter if the acrylic is opaque but could be a problem if it is transparent.
    Good Luck, David
    7/7       #3: Adhering Acrylic Sheet to MDF/Melam ...
    Travis Member
    I would make it "captive" . Use a U channel to wrap both pieces. They would float on each other.
    CA glue has no shear strength, so moving a large panel will flex it and could pop the glue points.
    One other thought is to use decorative screws, bolts, rivets, etc.....
    7/8       #4: Adhering Acrylic Sheet to MDF/Melam ...
    Jeremy
    David and Travis...thanks for the input. We're still kicking around the idea and not sure how we will proceed. I like the simplicity of the U-channel frame w/ no adhesive. Would certainly simplify the assembly. Will be something to consider.
    Thanks again for the thougths/comments..
    Jeremy
    7/8       #5: Adhering Acrylic Sheet to MDF/Melam ...
    smoen
    By decorative , do you mean like Vitracore , which has a painted side? If your plexi panels are clear then not many glues will work . You should take a piece of plexi and mdf and glue them together and see how much it pulls . I have glued vitracore to plywood using water based contact cement successfully but not as door panels only on fixed panels .
    8/6       #6: Adhering Acrylic Sheet to MDF/Melam ...
    Craig Weidenhammer
    Website: http://dura-pro.us.com
    if the volume is high enough to justify investment, think about PUR hot melt.
    8/9       #7: Adhering Acrylic Sheet to MDF/Melam ...
    al
    Website: http://solidsurfacealliance.org/blog
    Silicone, the acrylic has to expand with temp change.
    8/11       #8: Adhering Acrylic Sheet to MDF/Melam ...
    Jeremy
    All,
    Thanks for the replies. Currently we have found that the PUR adhesive is working out the best, utilizing a hot press.
    Al,
    We will check into the Silicone...thanks.
    Jeremy
    To receive email notification of additions to this forum thread,
    Date of Birth:
  • Buy & Sell Exchanges | Forums | Other Resources | Site Map
    Buy and Sell Exchanges
    Lumber Exchange
    Machinery Exchange
    Classified Ad Exchange
    Forums
    Adhesives Forum
    Business and Management Forum
    Cabinetmaking Forum
    CAD Forum
    CNC Forum
    Professional Finishing Forum
    Forestry Forum
    Project Gallery
    Commercial Kiln Drying Forum
    Sawing and Drying Forum
    Solid Wood Machining Forum
    Veneer Forum
    WOODnetWORK
    Other Resources
    Industry News
    Video Library
  • Questions or criticisms regarding Forum policies should be directed to WOODWEB's Systems Administrator
  • Forum Posting Form Guidelines
    Thread Related File Uploads Thread Related Files posted at WOODWEB's Forums and Exchanges should provide supporting information for the topic being discussed in the current message thread. Video Files: acceptable video formats are: .MOV .AVI .WMV .MPEG .MPG .FLV .MP4 If you encounter any difficulty when uploading video files, E-mail WOODWEB for assistance. The purpose of WOODWEB Forums is to provide answers, not to serve as an advertising venue. A Thread Related File that contains inappropriate content will be removed, and uploaded files that are not directly related to the message thread will be removed. WOODWEB reserves the right to delete any messages with links, files, or images it deems inappropriate. (return to form)
    Refer a Friend || Read This Important Information || Site Map || Privacy Policy || Site User Agreement
    Letters, questions or comments? E-Mail us and let us know what you think. Be sure to review our Frequently Asked Questions page.
    Contact us to discuss advertising or to report problems with this site.
    To report a problem, send an e-mail to our Webmaster
    Copyright © 1996-2010 - WOODWEB ® Inc.
    All rights reserved. No part of this publication may be reproduced in any manner without permission of the Editor.
    Review WOODWEB's Copyright Policy.
    The editors, writers, and staff at WOODWEB try to promote safe practices. What is safe for one woodworker under certain conditions may not be safe for others in different circumstances. Readers should undertake the use of materials and methods discussed at WOODWEB after considerate evaluation, and at their own risk.
    WOODWEB, Inc.
    RR4 Box 265A
    Montrose, PA 18801
    Contact WOODWEB
