Edge Gluing Carvel Planked Hull
8/21
I've been reading up for this application and sounds like Resorcinol would be superior than epoxy for this application. Do you carry both the "summer" and "winter" types? Because I'll be doing seams after planking I'll need a light filler with no clamping pressure.
I've heard concerns raised by traditional boat builders that finishing off the hull with epoxy, after edge-gluing, then two-part varnish will not hold up due to boat twisting, etc. Do you have any experience in this area?
Is Resorcinol more able to withstand this "flex" than epoxy-based adhesives?
Or should I just edge-glue then use traditional varnish?
Thanks!
PS - Planking is all new (but seasoned) philliphine mahogany
8/21 #2: Edge Gluing Carvel Planked Hull ...
Website: http://www.handrailer.com
Both carvel and lapstrake hulls are not glued at all but chalked (they are glued and screwed to the frames but the seams between the planks are always chalked). A carvel or lapstrake hull does "work" (flex) in a seaway.
Strip-built hulls are edge-glued and cold-molded hulls are cross laminated. What kind of a boat are you building?
Canoes, and kayaks are often made from thin strips, edge-glued and sheathed in glass and epoxy (inside and out). A transparent "bright" finish is an option.
Cold-molded hulls are also glassed and painted.
Traditional wood planked (carvel) hulls are chalked and painted with marine coatings. Varnish is not recommended below the water line.
And...Philippine Mahogany is not generally recommended for planking since the wood absorbs water. You might therefore want to consider a penetrating epoxy sealer prior to any chalking or paint.
8/29 #3: Edge Gluing Carvel Planked Hull ...
Website: http://www.prestigecasework.com
Be very careful. Jim Baldwin is right on. The planks are not edge glued at all. Even the most modern runabouts are not edge glued when solid planked. Typically the caulking would be flexible and never rigid. Sika flex or 5200 is even difficult to repair ten years later when the occasional repair is necessary.
5/14 #4: Edge Gluing Carvel Planked Hull ...
U can edge glue and dowei carvel.. it is done with vessels that r going tone out of water for extended periods..
Use West system epoxy..
Cheers..
Huey
Buy & Sell Exchanges | Forums | Other Resources | Site Map
Buy and Sell Exchanges
Lumber Exchange
Machinery Exchange
Classified Ad Exchange
Forums
Adhesives Forum
Business and Management Forum
Cabinetmaking Forum
CAD Forum
CNC Forum
Professional Finishing Forum
Forestry Forum
Project Gallery
Commercial Kiln Drying Forum
Sawing and Drying Forum
Solid Wood Machining Forum
Veneer Forum
WOODnetWORK
Other Resources
Industry News
Video Library
Repeated Forum Abuse:
Forum Posting Form Guidelines
Your Name
Your Website
E-Mail Address
Subject
Thread Related File Uploads
