Subject: Re: doors in 1923
doors in 1923
11/1/16
doug mclaren  Member
this from my grandmothers wish book circa 1923. morgan milkwork chicago ,oshkosh, and baltimore
11/1/16       #2: doors in 1923 ...
TonyF
Looks like the applied bead molding on the bottom of the panel on the bottom right door on page 239 is asking for trouble.
11/1/16       #3: doors in 1923 ...
I toured the Oshkosh Plant in 1984, and was able to see the entire operation. They make the dowels 5/8" in diameter, and bore at 9/16". They glue the dowels only and use cast iron hydraulic presses to drive everything up tight, then remove the door immediately, relying on the dowels to clamp and hold them together. No glue squeeze out on the faces, so they just stack the doors up face to face.
Since there is no glue on the copes (like 98% of big door makers) water eventually gets in and starts the process up to reclaim the door.
I did like the steamed Pine stile faces getting sliced over 1/4" thick on a hydraulic wedge machine, then they went off to be dried.
11/2/16       #4: doors in 1923 ...
Mark  Member
I used Morgan doors- 3 -15 lite, 1 single half lite- here at my house, 20 years ago. Only brush them with a waterproofing every couple of years. Outside of some gouges from dog claws, they're doing just fine.
Some designs and methods just work, despite all we know.
