Subject: Re: Splits developing
Splits developing
3/14/18
Tom Jones
We had some wood in our shop and in racks for 6-9 months. We got it down, machined it, glued it up, and days later are seeing some surface and end checks develop. The temps and weather have been pretty stable of late and during us working this wood. Any ideas?
3/14/18       #2: Splits developing ...
Species and thickness? Oak is famous for having cracks from too rapid of air drying, that appear to close in the kiln. They can open up again.
3/14/18       #3: Splits developing ...
Tom Jones
jatoba and tigerwood. 8/4 for both.
3/15/18       #4: Splits developing ...
Moisture content? Before and after? What is the RH in your shop? Is the storage RH and temp the same as the machining area? We have a hard time keeping our shop above 30% this time of year. In our area 35% is the preferred RH for interior wood and people.
Sudden changes in environment do not make for sudden changes in lumber. This is the driest time of the year.
Beyond that, I don't know of anything solid to consider.
3/15/18       #5: Splits developing ...
Tom Jones
Machine area is the same as storage. Only difference is storage is on racks and these two woods are stored about 8' adn 12' off the ground. Our ceilings are 20' tall so most of the heat goes up there. I would think puling pieces that have been up there would be dryer and want to expand (and not crack), when pulled down to a wetter environment. Not that I would expect that much difference to exist between floor level and 12' off the floor.
3/15/18       #6: Splits developing ...
Some exotics take forever to dry, if ever completely dried. Do you know the history? Were they supposedly kiln dried? Doesn't surprise me one bit that jatoba and tiger wood cracked when cleaned up this time of year. That can happen years after sitting on a shelf.
3/17/18       #7: Splits developing ...
Mark
It's always good to surface and mill any lumber-particularly 6/4 and thicker- oversize and let it sit for a while. Even though it sits rough sawn and racked for several months, when you surface it, pores open and fresh surfaces will begin to react more often than not.
I know this isn't much help after the fact. I think you'll have to work on finishing techniques to cover the checks and such
