Brandt Optimat edgebander - -- 0 --
10/13
We just got a Brandt Optimat KD 77 edgebander. I am expecting that it can be adjusted and run so parts need little filing when they come out of the machine. We have one man feeding the machine and two or usually three men filing the edges after they come out of the machine. Which I think is 2 1/2 men too many. That when the machine is adjusted tight and maintained properly that the parts should need to be barely touched with the file.
What do you-all expect from this machine?
I appreciate any help you can give us.
10/16 #2: Brandt Optimat edgebander - ...
Edgebanders are probably the most finicky machines in a shop, having said that I would say that one guy should be able to keep up with removal and any filing or sanding. The Homag dealer in my area recommends training a couple guys on the edgebander and they are the only ones that ever run it, everyone else, DO NOT TOUCH!
Some variables apply of course, what type of edging are you using? What is the condition of the machine? What is the condition of your tooling? Is the material thickness you are banding consistent?
I have a Brandt 340 and when it is set up properly you hardly have to touch the finished product, but I band mostly with .5 mil edging. When I edge 3 mil and plastic laminate, there is a greater labor value filing or sanding.
10/16 #3: Brandt Optimat edgebander - ...
We run almost all .5mm. Mostly pvc some wood.
10/22 #4: Brandt Optimat edgebander - ...
Website: http://www.hwccustomcabinetry.com
Scott makes some good points. IMO, and experience, if you develop the proper adjustment habits & procedures, you should have ZERO hand work after edge banding (providing your machine is in good condition and functioning properly). You will likely need some good training to learn how to set up your machine properly, but with 2 extra guys after your bander, you are already spending this money plus some. An exception might be if you are trying to run 3mm pvc w/o corner rounding. Then you have to decide if you really have the right machine or not for what you are doing.
12/16 #6: Brandt Optimat edgebander - ...
I am looking to buy a used computer controller for my Brandt KD 56.
Anybody?
0 --
Buy and Sell Exchanges
Lumber Exchange
Machinery Exchange
Classified Ad Exchange
Forums
Adhesives Forum
Business and Management Forum
Cabinetmaking Forum
CAD Forum
CNC Forum
Professional Finishing Forum
Forestry Forum
Commercial Kiln Drying Forum
Sawing and Drying Forum
Solid Wood Machining Forum
Veneer Forum
WOODnetWORK
Galleries
Project Gallery
Sawmill Gallery
Shop Gallery
Shopbuilt Equipment Gallery
Other Resources
Industry News
Video Library
Repeated Forum Abuse:
Forum Posting Form Guidelines
Your Name
Your Website
E-Mail Address
Subject
Thread Related File Uploads
