finishing cost for gloss finish -- 0 --
2/25
I have a question about pricing for gloss finish. I'm building a set of cabinets that will have a counter and backsplash. I got a quote from a finisher for spraying the cabinets with 2 colors of precatalyzed lacquer. 85% will have an off-white satin finish, and 15% (the counter and backsplash) will be bright orange. I asked the finisher to quote me a price for the orange in both satin and gloss finishes. The total estimate with the orange in satin was 1,200. The total for the orange in gloss was 1,800. I'm new at this: is it standard to charge this much more for gloss finish? Can someone explain why? Is it just because of paint cost? Or is it more difficult to get a good finish? Thanks for the help. See image attached. Please note that cabinet interiors will be painted.
View higher quality, full size image (2880 X 1566)
2/25 #2: finishing cost for gloss finish ...
$1200 for spraying 9 square feet of satin orange lacquer? $1800 for gloss? I think your finisher may be huffing lacquer fumes.... I'd get another quote.
2/25 #3: finishing cost for gloss finish ...
Website: silvawoodworking.com
Duster, i think he meant for everything, he quote:
"The total estimate with the orange in satin was 1,200. The total for the orange in gloss was 1,800."
2/25 #5: finishing cost for gloss finish ...
Edi, upon further review, I believe you are correct. But $600 is still a lot for the maximum of one hour of extra work to mask the cabinet and change the lacquer in the gun to gloss for the orange section....
2/25 #6: finishing cost for gloss finish ...
Website: http://subercustomshutters.com
If you have used the guy often and there was a element of trust, I would ask him why the difference. A second quote never hurts either. The second color does add the cost of more paint, and I find when spraying high gloss colors that are dark, they take a lot more coverage/coats than white paint on white primer. It does sound high though, but every situation is unique.
2/25 #7: finishing cost for gloss finish ...
I wasn't clear. Edi was right. I should have said they wanted 600 more for gloss/bright orange, so 1800 total.
Just to clarify a little further, the orange parts are going to be delivered to the finisher as separate pieces, so no masking will be necessary. I'm going to assemble the parts after they are spray finished.
Thanks for the responses.
2/25 #8: finishing cost for gloss finish ...
In that case, I say he is definitely too high.
2/25 #9: finishing cost for gloss finish ...
Depends on what you mean by gloss. If you mean pick up a can of gloss orange and spray it on then that price is nutz.
If you mean a high gloss attained by sanding and polishing/buffing then the price is still a bit high, but not off the mark to much.
A lot of work goes into a polished high gloss coat.
2/25 #10: finishing cost for gloss finish ...
Depends if you just want gloss out of the gun like others are suggesting, or if you want filled and fine sanded filler/primer, extra coats of color or color and clear coat, extended time in the shop for the material to cure hard, wet sanding with at least 2 or maybe 3 grits, and at least 2 grits of compound, and 1 grit of polishing compound. There is gloss sheen, and then there is "piano quality" finish.
2/26 #11: finishing cost for gloss finish ...
Website: http://www.alfortunato.com
I agree with rich c., a high gloss polished finish is extremely labor intensive. You need to specify if all you want is an off-the-gun finish, a piano finish, or something in between. Wood prep also comes into play here to reduce flaws. The higher the gloss, the more the flaws show up. I don't think $600 more for a high gloss finish is unreasonable.
2/26 #12: finishing cost for gloss finish ...
A super high gloss buffed finish here in Florida runs 55.00 and up per sqft.
2/28 #13: finishing cost for gloss finish ...
Your customer will likely be unhappy with the results even if expertly done. High gloss top just doesn't make sense! Looks beautiful, for a few days.
3/2 #14: finishing cost for gloss finish ...
Thanks for the feedback everyone. Just a note that I got another estimate and it came in a little higher. So it looks like the going rate for gloss here in Brooklyn.
3/2 #15: finishing cost for gloss finish ...
A gloss finish is a lot of work and your custom orange color has to be mixed special. I don't think the difference is out of line.
0 --
Buy and Sell Exchanges
Lumber Exchange
Machinery Exchange
Classified Ad Exchange
Forums
Adhesives Forum
Business and Management Forum
Cabinetmaking Forum
CAD Forum
CNC Forum
Professional Finishing Forum
Forestry Forum
Commercial Kiln Drying Forum
Sawing and Drying Forum
Solid Wood Machining Forum
Veneer Forum
WOODnetWORK
Galleries
Project Gallery
Sawmill Gallery
Shop Gallery
Shopbuilt Equipment Gallery
Other Resources
Industry News
Video Library
Repeated Forum Abuse:
Forum Posting Form Guidelines
Your Name
Your Website
E-Mail Address
Subject
Thread Related File Uploads
