Hanging Acrylic Panels with no nails
5/13/20
PJ Member
Has anyone hung Acrylic where you have to scribe to the ceiling and wall next to it. But can't use nails and maintain a 1/8'' reveal? I know some use Z clips but how do you keep it tight to wall and Wall?
5/13/20       #2: Hanging Acrylic Panels with no nail ...
Alan F. Member
We use standoffs if its something like 3Form.
Have also used cables
View higher quality, full size image (1752 X 1168)
5/13/20       #3: Hanging Acrylic Panels with no nail ...
PJ Member
These have to be clean nothing showing
5/13/20       #4: Hanging Acrylic Panels with no nail ...
MarkB Member
You could use something like the Fastmount surface mount fasteners as long as you had a means you felt comfortable with for surface bonding the male fastener on the back of the acrylic.
https://www.fastmount.com/en/clip_system/standard%20range
5/13/20       #5: Hanging Acrylic Panels with no nail ...
MarkB Member
Alan,
By the way, nice render. What cable fastener system did you wind up using on those panels and how were they affixed to the diewalls? Do they have a means of leveling up above the grid?
5/13/20       #6: Hanging Acrylic Panels with no nail ...
Alan F. Member
Mark,
Those are 3Form systems, we are attached to dry wall walls and the cables go up about 10' above the ceiling to the deck above.
Alan
5/13/20       #7: Hanging Acrylic Panels with no nail ...
Tell the designer or architect to please specify the hanging method. When they leave it open like this, that means they have no idea how the installer can make it happen. But still want it to look like magic is holding them in place.
5/13/20       #8: Hanging Acrylic Panels with no nail ...
MarkB Member
Agreed on the lack of a spec' but its also an opportunity to float a much better option and shine.
5/13/20       #9: Hanging Acrylic Panels with no nail ...
Alan F. Member
I guess the first question is how translucent the material is.
The next question is how thick the material is.
The thickness will determine if z clips can be used and the translucence will determine how you attach the panel without seeing the attachment method. The thinner the panel is the worse it will look without a flat back.
You could use a mirror mastic and glue it to the drywall, maybe use some kickers and pads to hold it in place or hot melt dabs but that all depends on what you can see through the acrylic.
The more translucent it is the harder it is to hide glue or mastic which gets us back to either J or U channel trim or standoffs.
The problem with gluing to the wall is if the panel is flexible (thickness) then it will follow the wall and depending on sheen will reflect light and can look like a mess.
If its thin material have it pressed to a core and use clips or glue
A-
5/14/20       #10: Hanging Acrylic Panels with no nail ...
james e mcgrew  Member
call Kip Porter , at starhanger.com he has what you need
http://starhanger.com
5/14/20       #11: Hanging Acrylic Panels with no nail ...
TomB
I second Star Hanger. We have used them on the last 4-5 projects and love it. Clean install with nice lines.
5/14/20       #12: Hanging Acrylic Panels with no nail ...
MarkB Member
The star hanger zero or the Fastmount allow for no need for headroom for drop-in. Panels just push into place. We just completed a job with 1000 fastmount fasteners and they were very slick and good price. Ive never used the starhanger zero so no idea on cost.
View higher quality, full size image (2260 X 1271)
2/23/22       #13: Hanging Acrylic Panels with no nail ...
Gregg Nelson
    • GreCon
    • INNERGY
    • CP Adhesives
    • Western Dovetail
      Custom Made Dovetail Drawers
    • Charles G.G. Schmidt Co.
