I think you need to have a 0 in the c field of the programs if you put in a 1 the programs run one after each other. The following is explanation of all fields from Help file.
1.13 MIX EDITOR
The functions provided by this environment closely resemble the functions in PGM TEXT EDITOR; The functions available here are:
. [F2] Saves the program on disk;
. [Ctrl]+[F2] Save with name;
. [Shift]+[F2] Confirms the instruction;
. [F3] Selects a MIX step from the PGM LIST;
. [Shift]+[F3] enables/disables BLOCKS functions;
. [F4] INSTRUCTION LIST (only in Enter mode);
. [Shift]+[F4] MIX LIST;
. [F5] deletes current instruction;
. [Shift]+[F5] selects / deselects the GUIDED EDITOR;
. [F6] selects/deselects new instruction enter mode;
. [F7] PGM EDITOR;
. [Shift]+[F7] opens the parameter table for the currently selected PGM.
Multiple selection of mix steps from the PROGRAMS ARCHIVE (key [F3]) is enabled.
The format of a mix step instruction is:
/ program name;
DX size X of panel;
DY size Y of panel;
DZ size Z of panel;
- work area on which the program is to be executed. The permitted values are A, B, C, D, AB, BA, CD, DC, AD, DA;
/ name of tool-up configuration file;
C machining type. The permitted values are 0 for normal machining and 1 for uninterrupted machining.
T enables/disables (1/0) raise bars (if present).
R number of identical panels to produce (max. 9999).
* unit of measurement. Permitted values are MM (millimetres) and IN (inches). If this field is omitted, the default unit is that specified in the machine parameters.
# name of environment variables file
BX size X of any additional shim or block located under the panel
BY size Y of any additional shim or block located under the panel
BZ size Z of any additional shim or block located under the panel
V activates / deactivates the clamping of the piece and the position control of the automatic suction cups, if present, according to the table below:
Field V Blocking Automatic Suction Cups Control
Blank Yes, using the system configured inXILOG3.CFG; if both vacuum and pressureswitches are mounted, the vacuumswitches are used Yes
0 Mechanic No
1 Mechanic Yes
10 Yes, using the vacuum switches No
20 Yes, using the pressure switches No
11 Yes, using the vacuum switches Yes
21 Yes, using the pressure switches Yes
30 Yes, using pressure and vacuum switches No
31 Yes, using pressure and vacuum switches Yes
