Deleting a machining program-Weeke PTP
2/26/15
Can anyone explain how to delete a machining program from the machining screen on my Weeke BP60?
I deleted some unused programs in Woodwop but they still show up in the machining screen selection menu.
Thanks in advance.
2/27/15 #2: Deleting a machining program-Weeke ...
Jim, once you generate a Woodwop file it creates a program file. I believe it's extension is pr4. In the C drive find WW4_A1_pr4 and you will find the files in there. If you generate the programs mirrored in x you will find 2files of the same name but one of them will have a .ges extension. That file is the mirror. So as an example if you create a part in Woodwop and generate it as you were going to send it to the machine you will be creating 2 files of the same name. One for the image as drawn and one for the mirror in X of that image. Those are the files you need to delete.
2/28/15 #3: Deleting a machining program-Weeke ...
Thanks I will give it a try in the morning.
3/2/15 #4: Deleting a machining program-Weeke ...
program files are where Jim said (~WW4\A1\PRG), blocks and poly's are in the ML4 folder. Blocks should be kept but ply files would depend on whether you wanted to keep the ply/mpr pair
A-
