Biesseworks - Parametric
5/17/17
JOHN ALVES Member
I was working on a program for a parametric Kitchen door and I can't get it to come out right. I did a drawing in AutoCAD (which I'm attaching a pdf file of that) and it's fine. However the .bpp file looks a bit off to me (I'm also attaching that as well). But when we run the program it's off (I'm attaching two pictures of the machined part). Any ideas what I need to do to fix this?
CITDAL_DOOR_CRISS_CROSS_2.pdf
View higher quality, full size image (1368 X 1539)
5/18/17       #2: Biesseworks - Parametric ...
Dan
Turn on your tool paths display.
I think you have a combination of problems but you'll need to get the geometry working first.
It may be easier to create the geometry, get it to work parametric and then attach millings.
