need a cheap 4 x 8 cnc router
3/9/18
michael ricchiuto Member
I'm starting a new business . In need of an affordable 4 x 8 CNC. I cant seem to find any besides the vey expensive routers. I'm only manufacturing 1 item so will only need the xyz axis. Any input would be helpful. Tank you.
3/9/18       #2: need a cheap 4 x 8 cnc router ...
I'd suggest you find a shop to cut the parts for you. No machinery investment at all then. If cheap and 4x8 are your only requirements, import one from China.
3/9/18       #3: need a cheap 4 x 8 cnc router ...
Affordable in terms of initial cost or in terms of operating cost or in terms of part cost.
Not all the same.
3/9/18       #4: need a cheap 4 x 8 cnc router ...
Chevy
Cheap = headache
Research a lot,,before wasting 15k
Cost router
Rigging
Installation
Air
Electrical
Dust collector
Air dryer
Software
Salesmen/youtube put on a great show,,
There are generations of experience on this website,,
Chev
3/10/18       #5: need a cheap 4 x 8 cnc router ...
B.H. Davis Member
I visited Don at DB CNC Routers last weekend and was impressed with what he is producing in the $7000.00 range. This is really inexpensive for any 4x8 router but his construction and knowledge are solid. I'm actually considering one of his machines for my own home shop.
At that 4x8 entry price range you get stepper motors on all 3 axis, lead screws on X and Z and rack and pinion on Y. You also get Mach3 software and a tower PC. The spindle is small but extremely quiet and comes with a single phase input inverter. There are numerous upgrades available including servos and higher HP spindles.
Don has been making these machines for a number of years and has numerous satisfied customer references. I'd suggest checking out his machines at the link below.
DB Cnc Routers
3/10/18       #6: need a cheap 4 x 8 cnc router ...
katz
we have second hand ,but after recondition
with servo motor ,weihong controler(windows xp) very good condition
5k
without vacuum table
also have one second hand usa made
with steper motor and included vacuum table
same price
3/11/18       #7: need a cheap 4 x 8 cnc router ...
We should probably start with what parts are you making?
4/27/18       #8: need a cheap 4 x 8 cnc router ...
leon513  Member
Website: http://www.hicasmachinery.com
The factory that produces woodworking machinery from China mainly deals in panel furniture, cnc router, edge banding machines, and sanding machines. And we have CE certificates that meet international standards. We have our own patents for some machines. If you are just a furniture factory that needs our machines, first of all, we will provide you with customized machines, make machine adjustments according to your process, and then help you out with a complete set of factory planning services. If you are an agent, we will provide a prototype based on your market needs. The service department will provide technical training for you and will help you to do exhibitions and branding. Please come to the vendor to discuss the form of cooperation that is more in line with your requirements.
View higher quality, full size image (800 X 800)
https://www.hicasmachinery.com/product/atc-cnc-router.html
6/5/18       #9: need a cheap 4 x 8 cnc router ...
Cherry Stylecnc Member
Website: http://stylecnc.com
Jinan Style Machinery Co.,Ltd specializes in the development and manufacture of CNC router machines. we have cheap and high quality CNC router machine for your choose.
welcome to contact with me.
View larger image
View higher quality, full size image (720 X 540)
https://www.stylecnc.com/cnc-wood-router/Wood-cnc-router-machine-STM1325-price.html
6/7/18       #10: need a cheap 4 x 8 cnc router ...
JOHN A WALKER  Member
I have a 5ft. x 12ft router with time to cut
if you are interested in having someone cut for you.
7/14/19       #11: need a cheap 4 x 8 cnc router ...
Zomai CNC
Website: http://www.zomaicnc.com
Jinan Zomai CNC Machinery, the professional CNC router and wood turning lathe machine manufacturer in China. We have cheap and high quality CNC router machine for your choose. welcome to contact with me.
View larger image
3/4/21       #14: need a cheap 4 x 8 cnc router ...
BuyCNC Member
Website: https://buycnc.com
This is a multi spindle drilling milling machine,it supportspindle integrated control for multi-head from 2 to 4pcs.You can can delivery command to spindles to work in tandem, also can work similarly as CNC router with an auto tool changer.This 4 spindle CNC machine kitchen cabinets allows users to set different tool path for different spindles (cutters), similar working mode as an auto tool changer.When the first spindle complete its work, the second spindle (cutter) can go on its own work automatically.The most important advantage of the multi spindle cnc router for sale is its high speed of spindle changing or we call it cutter changing.It only takes 2 seconds to turn on the spindle in advance for preheating.And you can use different spindle, from 800w to 6.5kw, do not have to use 8.5kw ATC spindle to drill holes. 4 spindle cnc router
View higher quality, full size image (569 X 440)
Multi Spindle CNC Router For Sale
5/30/21       #15: need a cheap 4 x 8 cnc router ...
FORSUNCNC Member
Website: https://forsuncnc.com/
If you need to buy a 4*8 CNC router machine, I suggest you check it on our website. There are many models in it, and the product is cost-effective.
FORSUN Smart CNC router machine is a high-quality Wood CNC Router that fits for 2D and 3D milling, cutting, engraving, carving, and slotting in relatively little time on wood, plastic, PVC, Acrylic, Aluminum, and any other materials. This CNC Router is one entry-level Wood CNC Router Machine. Easy to learn and operate and comes at a low price.
View larger image
    • Biesse America
    • Country Saw & Knife
    • Limtech Industries, Inc.
    • Charles G.G. Schmidt Co.
    • Palmetto Cabinet Doors
