CNC Offload
3/10/18
Stewart Member
After running a cnc for a couple of years, I can see the benefit of an offload conveyor setup (I don't need the onload feature). I've already talked to my machine company and they cannot retrofit. They said it would be too involved at this point and I don't really want to start over with a new machine as I really like how this one handles. Does anyone have experience or know of a company that could help me do something like this to an existing machine? I would love to integrate vacuum as well but realize I would most likely still have to manually blow the spoil board between cycles. Thanks in advance!
3/10/18       #2: CNC Offload ...
Stuart
It will not be cheap but potentially possible. Doucet makes conveyor table but you will still need to retro fit the machine with a push off device. Your best bet is to find a local machine shop.
3/10/18       #3: CNC Offload ...
What kind of machine?
I'm working on the same idea myself.
3/10/18       #4: CNC Offload ...
Stewart Member
It's a NewCnc Series 2 with Osai control. I'm not too worried about the conveyor - I know several companies produce those with the photo eye to keep product from sailing off the end. It's the push off device itself and then getting everything integrated into the control so that it would cycle at the right time that I would need help with.
3/10/18       #5: CNC Offload ...
The mechanical should be relatively easy.
First, try NewCNC and see if there are any unused M Code outputs that you can use. If you didn't get all the options on the machine, there may be some existing relays/solenoids that you can tie into.
Then all you need to do is appropriate that particular M code for whatever you want. Doesn't matter the original intent.
I'd put an air knife on the back of the push bar. That should keep the table clean.
3/10/18       #6: CNC Offload ...
Stewart Member
Dropout, now that you mention it, I do recall them saying there were some additional solenoid(s) that could be tied into. I will tap into them again to find out the specifics. I was hoping I could just take an existing push-off system and modify it but I may have to start from scratch.
3/11/18       #7: CNC Offload ...
Keep in mind that the drive may be overloaded pushing the sheet of if it was not designed for it.
3/11/18       #8: CNC Offload ...
It's a matter of speed. I wouldn't want to unload at 1000 IPM anyway :)
3/11/18       #9: CNC Offload ...
Both of my machines were built with offload, they are larger machines and they have a limit that’s why I mention it.
3/20/18       #10: CNC Offload ...
Bob
I have a new output conveyor we are not using. If you can get the rest figured out let me know if you have any interest.
located in Charlotte, NC
