CNC ROUTER
11/6/20
leonard hofer Member
Does anyone out there run a Holzher Dynestic 5 axis flat table nesting machine ?
is that something a guy should be interested when 85 percent of our work is standard cabinet cutting,cause it seems they don't come with a push off,
11/6/20       #2: CNC ROUTER ...
This has been covered before. My conclusion was a 5 axis head can present significant problems when it is crashed. Unless your need for 5 axis is significant enough it is likely not a good idea to try and mix nesting and 5 axis.
Also push off is such a significant time saver if it is not available that should be a show stopper. Busellato makes a similar 5 axis machine. Not sure if it has push off.
Good luck!
    • Country Saw & Knife
    • Charles G.G. Schmidt Co.
    • Biesse America
