Subject: Re: Black Walnut Finishing
8/24/16
Josh E. Member
Hello,
Admitted Finishing-Rookie here attempting to make sure I do this properly. All other woodworking skills are based around carpentry, not finishing.
I have a Slice of live edge Kiln-Dried (no steam) Black Walnut approx. 71"x18" that I am making into a Bartop. The piece of wood has great coloring and I want to preserve that as much as possible, while making sure that I protect the wood long-term, from spills, scratches, etc... Another Added issue is I need something that will solidify/strengthen/protect the Bark on the live edge from breaking and chipping off. It's a true rough-cut so not sure if I should Stain and Poly or what the best way is to go about it.
Any and all insight would be appreciated. Thanks in advance, I'm really looking forward to this project and will post "After" pics when Completed.
-J.E.-
8/24/16       #2: Black Walnut Finishing ...
RobertJ
EPOXY.
Try this:
Link
8/24/16       #3: Black Walnut Finishing ...
Nick
l agree epoxy. l like Smiths clear penetrating epoxy sealer (cpes). Soaks in and buttons things down and also is great for keeping the water out of the wood. As a matter of fact one of my finishing jobs today was a turned black walnut sink (a wood sink?!) with a partial live edge with the balance of the edge saw cut to mimic a live edge and I used the cpes to seal and 4 coats of rudds 1k pu to finish (I would use 2k pu but this how the wood turner wants it finished) I've finished a few of these and they come out beautiful. If I could figure out how post a pic I would.
8/24/16       #4: Black Walnut Finishing ...
Epoxy will make it look like a piece of plastic. I really hate it on the bark. Makes it look like a cheap flea market clock! Use a flat sheen catalyzed varnish.
8/24/16       #5: Black Walnut Finishing ...
nick
I'm guessing Rich has not used Smith's CPES, it is a penetrating not a surface film forming sealer, it no more changes or plasticizes the look of a project than a coat of vinyl sealer (less in my experience). since it's main use is to stabilize rotten wood; it's great at buttoning down porous surfaces (bark, punky sap wood). and since it's epoxy and it penetrates it has no known peer when it comes to keeping water out of wood. I use it as a sealer for exterior doors and furniture, wood counter tops and restaurant tables. It's a bit spendy but a little goes a long way. I've top coated it with 2k and 1k pu, cv and spar varnish with no problem.
8/25/16       #6: Black Walnut Finishing ...
I was replying to Robert J.'s post on pourable epoxy table top finish.
8/26/16       #7: Black Walnut Finishing ...
nicko
i was always under the impression that you take the bark off because it will eventually fall off any way. Maybe not, but thats what i was told and have read
nicko
