Graco airless GX19
9/19/18
Mark Sibbers Member
I'm considering buying an airless Graco GX19 with the hopper, I mainly spray vinyl sealer, CV and tinted CV. I'm a one man shop and spray about once every few days or so. I catalyze in small batches. I like the idea of having a hopper on it. Any pros/cons from anyone who has one?
9/21/18       #2: Graco airless GX19 ...
Shane
your better off dealing with a small pressure pot and a good gun at that price point and amount of cleanup involved to keep that thing clean... Pressure pot is going to deliver material faster and atomize better than a cup gun. if it's strictly a budget issue you could spend a bit more and get one of the CAT 15:1 AAA pump setups that will give you excellent finish and service life for a small shop...
9/21/18       #3: Graco airless GX19 ...
DannyB Member
I have one. I also spray in small batches most of the time.
I do not use my GX19 to do it.
As the other person said, it's more work to keep it clean than it would be to use a pressure pot with liners.
11/4/18       #4: Graco airless GX19 ...
Mark Member
I ended up trying a cheaper pressure pot system just to try one but it seems like there was an inconsistency in pressure with my air compressor. Didn't care much for the extra hoses going to the gun either. I was spraying tinted CV so the solvent to clean was affecting the gaskets too. Went to plan B and got a GX19 with the hopper, fine finish tip, using a 10' hose. Pretty happy with the unit. Sprayed doors today with vinyl sealer then switched over to CV, happy with the results. cleanup was easy, but used a little more solvent. Ran the solvent used in thinning the CV through first, then finished off with a cheaper lacquer thinner.
7/14/20       #5: Graco airless GX19 ...
Mark Member
Thought I'd post a follow up for anyone considering this unit. After about a year and a half of use I can say I'm very happy with the unit. It took some playing to get the right tips. Ended up going with a Fine Finish 208 for spraying clear and tinted conversion varnish. Cleanup isn't bad. I run solvent through the hose and gun until the material is cleared, then remove the hopper and wipe with solvent rag, then run more clear solvent through, sounds like a lot of solvent but it's not as that unit doesn't need much. You can have primed hose on less then 6 oz of material with a short hose. I'm considering a second one just for clear only, leaving this one for tinted as that segment has really got popular lately.
