Z Clips on solid surface -- 0 --
6/12
I've done allot with solid surface now I need to put Z clips on the back of a 1/2" thick sheet. I wanted to know if any one had a good way to do this......the panel will be part of an elevator. Thanks in advance for any ideas.
6/14 #2: Z Clips on solid surface ...
Inserts?
6/17 #3: Z Clips on solid surface ...
Website: http://www.maximasa.com
I'm about to install a few sheets as wall covering this week. I made my own "z" clip by glueing a strip of SS material on the back that has a 30 degree angle. Then I screwed a piece of 1/8" aluminum strip for added security. The lower "Z" clip is made from 2 strips of 2" x 3/16" flat steel strip about 4" long that I will screw against the wall about every 2 feet. See attached picture.
Jan
Mounting_Detail.pdf
6/18 #4: Z Clips on solid surface ...
awesome thats a great Idea really thank you for the detail
6/25 #5: Z Clips on solid surface ...
The screw into the SS isn't a recommended practice by the manufacturers! It creates a stress point. I would think the French cleat set with seaming adhesive or epoxy would be sufficient.
10/8 #7: Z Clips on solid surface ...
I use epoxy to fasten the clips that hold under mount stainless steel sinks to solid surface and it works fine. Why not do a mock up to check it out.
Make sure to sand the solid surface where the Z clips will go with 60 or 80 grit paper to ensure a proper bond for the epoxy.
0 --
Buy and Sell Exchanges
Lumber Exchange
Machinery Exchange
Classified Ad Exchange
Forums
Adhesives Forum
Business and Management Forum
Cabinetmaking Forum
CAD Forum
CNC Forum
Professional Finishing Forum
Forestry Forum
Commercial Kiln Drying Forum
Sawing and Drying Forum
Solid Wood Machining Forum
Veneer Forum
WOODnetWORK
Galleries
Project Gallery
Sawmill Gallery
Shop Gallery
Shopbuilt Equipment Gallery
Other Resources
Industry News
Video Library
Repeated Forum Abuse:
Forum Posting Form Guidelines
Your Name
Your Website
E-Mail Address
Subject
Thread Related File Uploads
