Sawing and Drying
Short needle pine for pier
5/24/16
Philippe Member
Hi I would like to build a small (12 by 12') pier over the edge of a pond. We have abundant eastern red cedar but mostly in the 3-4" range and quite a lot of short needle pine (this is Middle TN). would building the deck and framing with the SNP worth doing or will it rot in no time ? How about using a copper sulfate solution to protect it ?
Thanks for opinions !
5/25/16       #3: Short needle pine for pier ...
Gene Wengert-WoodDoc
Not every piece will rot right away, but some will...if 1/10 or 1/20mdo, is this a failure? If so, consider taking your wood to a pressure treater. Many can slip your small quantity in with larger loads. Without pressure, any surface cracks are likely to expose untreated wood. Also, a brush or spray treatment is irratic in coverage. "If it is worth doing, then it is worth doing right."
Because borax is water soluble, it is not a good choice for your project.
5/25/16       #4: Short needle pine for pier ...
Won't copper sulfate just kill algae? Not sure it gets you any rot resistance. Be careful trying diy wood treatment around a pond. Could have consequences with the pond inhabitants!
5/26/16       #5: Short needle pine for pier ...
Keith Newton
It has been a while since I've had any custom treated, but it was very reasonable.
The told me to sticker it for a month, then stack it dead before bringing it, and make sure that they can pick it up off your trailer with their forks.
