Sawing and Drying
4/4 Hickory
1/6/17
Bruce Member
I'm having problems with cupping and side bend in 4/4 Hickory. We are stickering every 12" with BreezeDry sticks.
1/8/17       #2: 4/4 Hickory ...
Gene Wengert-WoodDoc
Cupping is a normal tendency for lumber sawn from near the pith of the tree. Cupping is encouraged by slow drying, by rewetting partly dry lumber, and by over drying. Sticker spacing or even weight on top of a pile does not seem to control cupping. Kiln drying or predrying in a predryer seems to get more cup than air drying. Cool, low humidities with a good roof in air drying and subsequent low humidity kiln conditions at start-up, both to prevent rewetting, seem to get the least cupping.
Side bend is totally caused by the wood properties and is not affected by drying. The main cause is that the rings are not centered (end view) edge to edge. This happens because of the sawing pattern; that is, usually moving from the opening face to an adjacent face rather than the opposite face.
1/9/17       #3: 4/4 Hickory ...
Bruce Member
So what would be an ideal average %MC loss per day to reduce cupping in 4/4 Hickory? Does sapwood tend to cup more than heartwood?
1/9/17       #4: 4/4 Hickory ...
Keith Newton
Bruce, Sapwood should normally have less tendency to cup than heartwood, in that it is further out where the arc of the rings is larger.
Cupping is due to the difference between the ratio of shrinkage between flat sawn, and radial, which is normally stated as average of 2 ~ 1, so the smaller the arc of the rings, the greater the propensity for cupping.
1/9/17       #5: 4/4 Hickory ...
Gene Wengert-WoodRoc
Sapwood and heartwood shrink the same basically. That is, sapwood does not cHange its shrinkage substantially when it converts to heartwood.
1/10/17       #6: 4/4 Hickory ...
Bruce Member
So,what average %MC loss per day will help reduce the cupping?
    • Forestry.com
