Sawing and Drying
Boxed heart posts
8/19/17
Chris Member
Hey there, I'm starting to cut 6x6 poplar timbers for posts in a garage I'm going to build. I read a lot about boxing the heart on the timbers but that means I can only get 1 timber per log. Is there any reason that I can't saw a 12x12 cant and then saw 4 posts from that? Seems like such a waste of wood to only cut 1 post from each log.
8/19/17       #3: Boxed heart posts ...
Tom the Sawyer  Member
Website: http://www.TomTheSawyer.net
If you saw 4 posts from a 12x12 cant, you'll be sawing through the heart both ways. That would mean heartwood on the corners of all four posts and it is likely that all four will bow significantly. If you have a large cant I have found you can get more than one post out of a log, just keep the heart about an inch or so away from any milled surface. You could mill posts about 1-1.5" above the heart, flip it and mill above the heart the same distance. Hence the terms, "heart-centered" or, "FOHC ; free-of-heart-center".
8/20/17       #4: Boxed heart posts ...
Gene Wengert-WoodDoc
Tom has given good info. Let me explain why he is correct. The center portion of the log, perhaps the first 15 growth rings, will shrink lengthwise, while wood further away will not shrink lengthwise, very much if at all, as it dries. So, in you scenario, your posts will be shrinking lengthwise on one edge or corner and not the other regions, so you will see lots of bend.
When sawing, if you plan to box the heart, the wood outside the heart can be sawn into various sizes and , for example, three or four 2x6s could be bolted together to make a post that could work for a barn. Have an engineer or architect design the size and fasteners to,achieve the needed strength. You could even glue them as well as bolting them.
Note that yp does not have substantial decay resistance, so you will need to avoid ground contact. Concrete piers and appropriate fasteners should work if kept dry.
2/19/22       #6: Boxed heart posts ...
Mark Matthews Member
This is the core of the message that needs to gotten out to young high school grads looking for work. But nobody seems to think that matters, so it is not mentioned.
    • Forestry.com
