Solid Wood Machining
Shims on Newman Whitney Planer
9/9/16
JeffN Member
I have a 24" Newman Whitney planer with the "old style" adjustment screws to adjust the level of the planer blades. Since I use a special tooled set of knives on this machine, they have to be 12" long, so each set is comprised of two knives to make the 24" length. This creates a problem with trying to use the adjustment lift screws to adjust the knives and keep them level. Is there any reason why I can't remove the lift screws and use a shim in each slot to hold each set of knives at the proper height?
