Solid Wood Machining
best way to move powermat 700 into place from the crate
4/8/17
Ian Member
Any of you guys uncrated a powermat 7000? I have the front off, but can't really see any lifting points. It has a tag recommending that lifting be done from the top, but that moves the center of gravity too high for our lift. I really don't want to screw up the bosses new toy so any help is appreciated.
4/8/17       #2: best way to move powermat 700 into ...
Russ
Hire a rigger !
4/9/17       #3: best way to move powermat 700 into ...
I agree on the rigger. I think that is 9-11,000 pounds.
The material that came with it usually gives the pickup points and the center of gravity.
4/13/17       #4: best way to move powermat 700 into ...
rob
there are colored ribbons through the castings showing where the straps should be routed for lifting. Key word- straps. At a bare minimum, rent a lift capable of lifting it properly. Even a rigger as others have suggested is cheaper than a broken casting, positioning motor etc after you have made a cock of it trying to do it on the cheap....
4/14/17       #5: best way to move powermat 700 into ...
Ian report back on what you ended up doing please.
4/26/17       #6: best way to move powermat 700 into ...
Troy
Two overhead boom trucks and an I beam.
4/26/17       #8: best way to move powermat 700 into ...
Ian Member
We ended up cabling overhead to the forks on our large toyota lift and hoisting it, Didn't think the old girl could handle it, but no problem. Next job is the promaster 7225XL
