Exterior Wood to Brick
6/17
I am working on a historic home. Customer is upgrading the storm windows. There is quarterround next to the brick, I was going to originally replace the quarterround, but I don't think I could find a good wood replacement that would hold up as lond as these did (120 years). I am going to repair the wood with epoxy. My question is each window has about 1/4" gap between the wood and the brick, you can see where various caulks have been used and failed between the wood and brick. As I clean out the failed caulk, what should I replace it with? A mortar? Any recommendations?
6/18 #3: Exterior Wood to Brick ...
Website: http://www.subershutter.com
Mortar would be a short lived solution. The gap is by design, to allow for the different movement and expansion of the wood versus the brick. Over the years, depending on who was doing the previous caulking, there may have been some inexpensive caulks applied, and then failed. Also we now have some caulkings that are rated for longer periods of time. I would definitely go back with a superior grade of caulk. Most historic restoration projects will suggest a caulk for use, if you are working for a homeowner, maybe the local historic society will suggest something. That a way you would have a valid recommendation that would hold with the customer if there as ever an issue.
7/16 #4: Exterior Wood to Brick ...
Do not use Latex and DO NOT use silicone. From my company's specifications: A. General Purpose Sealant shall be a high-performance, polyurethane type. Sealant shall conform to ASTM C920.
Make very sure to clean all dirt, dust, mortar off the brick to ensure bonding. I aso might suggest using a non-wood product for the 1/4 round.
PetrB
Buy & Sell Exchanges | Forums | Other Resources | Site Map
Buy and Sell Exchanges
Lumber Exchange
Machinery Exchange
Classified Ad Exchange
Forums
Adhesives Forum
Business and Management Forum
Cabinetmaking Forum
CAD Forum
CNC Forum
Professional Finishing Forum
Forestry Forum
Project Gallery
Commercial Kiln Drying Forum
Sawing and Drying Forum
Solid Wood Machining Forum
Veneer Forum
WOODnetWORK
Other Resources
Industry News
Video Library
Repeated Forum Abuse:
Forum Posting Form Guidelines
Your Name
Your Website
E-Mail Address
Subject
Thread Related File Uploads
