Gluing masonite to particle board -- 2 --
2/4
What is the best adhesive for gluing Masonite to particle board?
2/6 #2: Gluing masonite to particle board ...
It doesn't matter how good the glue is, other than a few things like contact cement, the glue will all be better than the internal strength of the masonite.
I'm sure you will get a better answer, if you explained your application.
2/14 #3: Gluing masonite to particle board ...
The heat used when manufacturing high density hardboard makes the surface unattractive for gluing with most common woodworking adhesives. Scuffing the surface will help a bit, but as mentioned the internal bond is not real high plus the surface fibers may not be well fasten to the core. How much bond strength do you need?
2/14 #4: Gluing masonite to particle board ...
I don't need a whole lot, just keep it in place. It'll be stapled as well.
2/14 #5: Gluing masonite to particle board ...
I am tempted to think that a construction adhesive might work in your case. Not positive, so test it out.
2/14 #6: Gluing masonite to particle board ...
Thanks.
2/23 #7: Gluing masonite to particle board ...
Website: williamolsendesigns.com/
Yellow Glue or any PVA Will work just fine.
First scuff if up then tack of dust
3/28 #8: Gluing masonite to particle board ...
A lot of particleboard has wax added when gluing. This provides a bit of moisture stability for the product, but lowers the glue-ability. It is critical to remove this outer layer by light sanding.
This is in addition to scuffing the Masonite.
2 --
Buy and Sell Exchanges
Lumber Exchange
Machinery Exchange
Classified Ad Exchange
Forums
Adhesives Forum
Business and Management Forum
Cabinetmaking Forum
CAD Forum
CNC Forum
Professional Finishing Forum
Forestry Forum
Commercial Kiln Drying Forum
Sawing and Drying Forum
Solid Wood Machining Forum
Veneer Forum
WOODnetWORK
Galleries
Project Gallery
Sawmill Gallery
Shop Gallery
Shopbuilt Equipment Gallery
Other Resources
Industry News
Video Library
Repeated Forum Abuse:
Forum Posting Form Guidelines
Your Name
Your Website
E-Mail Address
Subject
Thread Related File Uploads
