Adhesives
Gluing masonite to particle board
2/4/13
What is the best adhesive for gluing Masonite to particle board?
2/6/13       #2: Gluing masonite to particle board ...
Keith Newton
It doesn't matter how good the glue is, other than a few things like contact cement, the glue will all be better than the internal strength of the masonite.
I'm sure you will get a better answer, if you explained your application.
2/14/13       #3: Gluing masonite to particle board ...
GeneWengert-WoodDoc
The heat used when manufacturing high density hardboard makes the surface unattractive for gluing with most common woodworking adhesives. Scuffing the surface will help a bit, but as mentioned the internal bond is not real high plus the surface fibers may not be well fasten to the core. How much bond strength do you need?
2/14/13       #4: Gluing masonite to particle board ...
I don't need a whole lot, just keep it in place. It'll be stapled as well.
2/14/13       #5: Gluing masonite to particle board ...
GeneWengert-WoodDoc
I am tempted to think that a construction adhesive might work in your case. Not positive, so test it out.
2/14/13       #6: Gluing masonite to particle board ...
Thanks.
2/23/13       #7: Gluing masonite to particle board ...
William Olsen  Member
Website: williamolsendesigns.com/
Yellow Glue or any PVA Will work just fine.
First scuff if up then tack of dust
3/28/13       #8: Gluing masonite to particle board ...
Gene Wengert-WoodDoc
A lot of particleboard has wax added when gluing. This provides a bit of moisture stability for the product, but lowers the glue-ability. It is critical to remove this outer layer by light sanding.
This is in addition to scuffing the Masonite.
5/8/20       #9: Gluing masonite to particle board ...
Barry B Member
I have always found the Liquid Nails Construction Adhesive to be the best. All of them are good.
    • CP Adhesives
