Adhesives
unibond 800 exterior use
2/7/20
Kevin Member
I was wondering if anyone has experience using this product for exterior work. I have some laminated exterior door jambs to make and was wondering how it would hold up. I have used it quite a bit for interior applications, I like the fact that there is little to no springback and a long open time.
2/7/20       #2: unibond 800 exterior use ...
Jeff Pitcher
Website: http://www.cpadhesives.com
Kevin,
Unibond 800 should (when used properly) meet HPVA Type II water resistance standards. Essentially, it will give you good water resistance unless directly exposed to extreme conditions.
2/7/20       #3: unibond 800 exterior use ...
Jared
I have used it extensively for laminations that are exposed to cold and wet environments each year. I don't think I've had a glue failure yet. Other kinds of issues yes, but not related to glue bond.
2/7/20       #4: unibond 800 exterior use ...
Kevin Member
Thanks, I appreciate the help.
2/9/20       #5: unibond 800 exterior use ...
Kevin Member
After some thought, I may use titebond 2 extend for these curves. I’m concerned about shop temperature affecting the unibond. Shop stays in the mid- low 60’s. Has anyone experienced any issues with unibond 800 glue ups under 70 degrees?
2/9/20       #6: unibond 800 exterior use ...
Jared
I feel like any PVA glue is going to give more springback than plastic resin glue, but maybe that's not a concern for your application. I threw an electric blanket over the vacuum bag, which worked nicely. I was able to get 3 parts per day, each part in the bag for 4 hours with the blanket on high.
    • CP Adhesives
