Adhesives
What Kind og bander for smal shop
1/20/21
Mrsweden
Hi I am an small cabinetshop baser om northern europe and Are koking to buy my first bander. Does any og you guys for have any experince with virutex en 140 or the felder g330 or do you have any other tips on an ok small bander
1/21/21       #2: What Kind og bander for smal shop ...
I have never used either of those brands, I have owned Minimax, SCM , Holzher and Brandt edgebanders. I have worked in another shop that had Casadei.
My recommendation is to buy a bander with a glue pot, this gives you a large option for different tapes, if you can afford it I would get a machine that can do up to 3 mm.
Most importantly I would buy a machine that you have access to service and parts in your area. Banders are one of the most finicky machines in the shop so if you can’t get parts or service, what good is it.
As for brand a lot of folks on this site can tell you positive and negative stories for every brand I mentioned.
1/22/21       #3: What Kind og bander for smal shop ...
Nick
I have been using the little Safety Speed edge bander with a glue pot since I started out. I can apply up to 1mm, it does the job but there can be better options. For reference, I only use the bander 6 or 7 hours a week on average, a better bander would probably cut that time in half.
I’ve had the trimmers disconnected and scrape the faces off by hand, I’ve found that more often than not you need to scrape them anyway so taking off 1/64 or 1/8” doesn’t really make a difference. The 1mm has to be trimmed with a router, but I don’t use it very often.
I bought a much larger Brandt bander 5 years ago but haven’t hooked it up because I need to upgrade my panel and compressor. If you were planning on doing any kind of volume you should plan on a larger machine than the virutex. An acquaintance had the Felder and it worked quite well considering the cost.
1/24/21       #4: What Kind og bander for smal shop ...
Mrsweden
Thanks Nick that is really helpfull
1/27/21       #5: What Kind og bander for smal shop ...
MarkB Member
Late to this one, and know your not in the US, but we are a small shop with an older Holzher bander that runs almost like a top most of the time.. they can be a love-hate thing.
Being a small shop and doing varied work, I would never leave a cartridge style bander. The lack of headache with regards to a glue pot and the ability to change glue types and colors on the fly is something I would really miss for our work. Jumping from wood, to melamine, to black, white, etc. is super easy and our bander may sit for days then run non stop.
We've been very happy with the cartridge system.
5/28/21       #6: What Kind og bander for smal shop ...
Luciboo Member
Website: https://www.definitiveinspectionsmn.com/services.h...
I have an ancient Holzer from my Dad that we've been using for a long time. I can't vouch for any other brand of equipment other than this one has done the job and has held up for about 30+ years. It might be older than I am. Of course, nothing is made like it was in the "old days" so I can't speak to the quality that they're making now.
    • CP Adhesives
