Adhesives
HPL to HPL Adhesive advice
5/14/21
richard Member
Website: http://cfandm.com
I work on Yachts.
Have a situation with some horizotal interior surfaces of odd shapes need HPL glued over existing HPL.
Two things are of concern:
1. The best product for adhesion strength
wise that will also withstand heat from
the southern sun beating on it.
2. The areas are recessed down in with a
Teak border around them. Need an
adhesive other than contact cement
that will provide movement and at least
a few minute set time allowing correct
positioning.
The 6 areas vary in size and shape and are from 1.5 sq.ft. to 10 sq.ft. and all are
odd shapes.
5/26/21       #3: HPL to HPL Adhesive advice ...
I expect that you have made a decision already but...
My thoughts are either epoxy or PPR
You would need to scratch up the original laminate with coarse paper first and clean with acetone.
5/26/21       #5: HPL to HPL Adhesive advice ...
Richard  Member
Website: http://www.CFandM.com
Tom, Epoxy for sure does not work and I think PPL is about the same result.
Did some expeiments and am not going back in forth between ROO and Titebond for Melamine.
They are real close to the same, I'm on the last test...think the ROO clear is going to win.
5/28/21       #6: HPL to HPL Adhesive advice ...
I don't have much faith in melamine pva. With hpl to hpl there would be no where for the moisture to escape and besides the bond is not great even with ideal conditions.
Have you considered PL ? It would have to be trowelled out but has tack and sticks to anything
6/9/21       #7: HPL to HPL Adhesive advice ...
Steve
I would suggest first using a etching primer then a resin glue dry time is based on moisture drying up would need to hold in place with pressure pictures would help
6/9/21       #9: HPL to HPL Adhesive advice ...
Richard  Member
Solution is found and it was right in front of me and no one even though of it.
I use "Heat Lock" when I do veneering that can't be clamped or fit in a vacuum bag.
I did some samples and the things come out rock solid, you can not get it apart.
Sometimes you just "can't see the forest for the trees"
I bet someone Googles Heat Lock,
I've been using it for years. Best thing since sliced bread.
4/25/22       #10: HPL to HPL Adhesive advice ...
killersmile Member
Interesting post i love it keep posting more!
4/25/22       #11: HPL to HPL Adhesive advice ...
Cfm
The Heat Lock is rock solid, the one concern is use caution on two points. Don’t get the HPL too hot to damage it, do a test and make sure you use a new clean cloth when ironing.
I relation to another of my posts on patterns. It can be done. I’ll see if I can figure out how post photos. Folks told me I couldn’t make a good pattern and had to take all the gauges out…….wrong! Patterned and fit HPL around them.
    • CP Adhesives
