Adhesives
Glue choices for Cork to Plywood
6/27/22
Wes Priestley Member
I'm gluing some tiles onto plywood for a serving tray. The handmade tiles were wedding coasters so they have cork adhered to the back side. I've looked for glue options and lean toward epoxy. Is there any reason NOT to use epoxy? I've read that it "eats" away cork over time (???). Any other adhesives that do better? This is my first post so thanks for your help.
6/27/22       #2: Glue choices for Cork to Plywood ...
Rocketdc
What a trip to see Claremont on the back of the tiles, I went to school there years ago.
I don't see why Titebond or any PVA wouldn't work. Do a small test on the corner of one of the cork coasters and see how it bonds. Epoxy seems like overkill for this job, if there's any issues with the PVA bond I would try a PU adhesive.
If you have any technical concerns regarding a specific glue/epoxy, ex. if it will degrade a substrate like cork over time, contact the techs at the manufacturer of the adhesive.
7/31/22       #5: Glue choices for Cork to Plywood ...
I've got zero experience bonding cork to anything. The epoxy eats it got me interested. Epoxy is known for being relatively non reactive/inert when its liquid & hard because of it's lack of solvents. It does sound like overkill and not worth the expense.
8/18/22       #6: Glue choices for Cork to Plywood ...
Yellow PVA will work fine.
8/18/22       #7: Glue choices for Cork to Plywood ...
Priestley Member
Thanks y’all. I went with Tightbond 3 and moderate clamping pressure with a wood block on each tile, foam and plywood to distribute the pressure evenly. I don’t expect problems but since it’s a gift to California from Tennessee I’ll probably never know. Anyway. Thanks for all the advice. You guys are great.
2/16/24       #8: Glue choices for Cork to Plywood ...
Angel17 Member
spray adhesive (3M makes several varieties), you can use wood glue like any of the Titebond glues or you can buy self adhesive cork.
    • CP Adhesives
