Subject: Re: Hardware, hinges & slides for MRI room
4/10/18
David Martin Member
I need hinges, slides & pulls for a MRI room. Sugatsune says no, in a disclaimer. Has anyone built case work for a MRI room and what hardware was used?
4/11/18       #2: Hardware, hinges & slides for M ...
Joe Doherty
I was give a salvaged MRI door with frame and hinges and hardware. I no longer have it but the label on it said Universal Shielding Corp. www.universalshielding.com. Maybe they can help you find what you are looking for.
5/31/18       #4: Hardware, hinges & slides for M ...
DOUGLAS P CONTI Member
I have done a few in the past and we used standard slides and hinges with no problem. The entry door was on rixen hinges mainly because of the weight, it was 42 " wide 7 ft tall 1 3/4' thick with plam on both sides and lead lined. The metal jamb was also lead lined as well. It was the same as any standard x-ray room. Sheet lead was hung on the studs, sheetrock installed over that with lead on the screws to cover the penatrations.
