Subject: Re: Any Moulder Runners?
4/17/18
MillworkDave Member
Running a Kentwood M609X, and just had a spindle bearing go out on one of the heads, at least this is what I am suspecting. Horrible noise when running. Anyone change bearings on a spindle in one of these machines?
4/18/18       #2: Any Moulder Runners? ...
AM
Not that machine in particular but moulder bearings can be a little tricky. Usually a pair of matched preloaded bearings and shimming for end play is very important. Depends on your comfort level I guess. Not something you beat on and off with a hammer so the right equipment is paramount. Last one we froze the shaft and heated the bearings to slip on easily.
5/1/18       #3: Any Moulder Runners? ...
I've changed spindle bearings on my Weinig. They run a long time before any noise. I have a 20 ton Hydraulic press to take bearings off & put on. You will need Two angular contact bearings are set so they oppose each other and are loaded with very heavy star spring washers. Do not hammer precision bearings! Dry Ice helps in putting them on, but be quick. You don't have much time before the bearings and shaft equalize & seize.
