Shutter Hinges
3/10/15
Ed  Member
Website: http://www.thespeedofwood.com
I'm striking out at my normal suppliers.
Need a source for these shutter hinges.
The place was built in 1812, no one knows if the hinges are original or not. I need to find them because I'm looking at making 110 new shutters. They only have maybe 15 shutters worth of hinges, so I need to come up with something to "match". The shutters in the pictures were made about 1970, supposedly using the original hardware. Out of 110 shutters their are 4 left that are not falling apart.
3/10/15       #2: Shutter Hinges ...
If you can't come up with them try having them made by a place that does small batch casting. Brass might be a better choice.
3/10/15       #3: Shutter Hinges ...
Chris M
Website: http://dfmeyerinc.com
These are Acme, Lull, and Porter Hinges. Here is a link to a close set that has steeple finials which may be too Victorian.
www.houseofantiquehardware.com/shutter-hinges-6-1-2-inch-acme-mortis
e
If they do not satisfy your needs call Russel at Kilians hardware in Chestnut Hill, Philadelphia where I get all my stuff from. (215) 247-0945
3/10/15       #4: Shutter Hinges ...
Lull & Porter Acme Hinges, according to the Timberlane Hardware Catalog. I did not check the sizing, but the look is the same.
Timberlane will the most expensive place to buy these. If you beg, you might get 5% off.
Google it and I bet you will find several sources. Good luck, sounds like a nice job.
3/19/15       #6: Shutter Hinges ...
Calvert
You might try http://www.ballandball-us.com/. They have been helpful in either directly supplying or referring me to a good source. I believe the person I spoke to most is Robert.
3/20/15       #7: Shutter Hinges ...
Ed  Member
Just talked to .houseofantiquehardware.com very helpful & nice pricing, plus free shipping.
Thanks for all the info.
