Bending metal laminated panel
4/7/15
Jeff Dalton
Website: http://www.vanguardtops.com
How would you go about making a panel (approx. 3' long and 3' tall x 3/8" thick) with a 2' radius that will be laminated with metal laminate? It is only going to be attached at the corners with 4 metal standoffs to the back of a curved cabinet so it pretty much needs to maintain its 2' radius without being attached to anything. The top and sides will be seen, so they will need to be laminated as well, preferably before the face so you don't see the black line from the front.
4/7/15       #2: Bending metal laminated panel ...
This is one of those designs full of known risks. For a start ending a laminate on a curve, if contact is used, will almost always result in the perimeter wanting to peel back, at least some. Keeping to the standard practice of a balanced panel, both faces need to be laminated the same. The adhesive used must be rigid stting and it must fully cure before releasing the clamping pressure. The substrate should be a series of easily bent layers so that it will not act like a spring. I don't know how you are going to eliminate the dark laminate line. It will show either on the edges or the faces. You could reduce the viability by metallic painting it.
In our shop we would CNC the form and use the vacuum table to press the substrate and then to press the laminate faces if we were going to edgeband first.
4/7/15       #3: Bending metal laminated panel ...
Keith Newton
First, let me just say, that I will never use a metal face over high pressure laminate again. Apparently they have to use too much heat or pressure, which will cause it to grow over time as they gain MC.
I would use the solid aluminum type, then vacuum bag it to both sides of 3/8" bending ply, using epoxy for the adhesive.
You don't need to have the form inside the bag. It is a whole lot easier to just bend the bag around a form, then pull the vacuum after it is bent to your radius.
A straight 1x2 along the two straight sides will hold it to the form easier, and with less risk of a dent under the clamps there. But it will pretty much take a fair bend around the curve.
