Patchwork Plywood
2/29/16
Jarin Smoker  Member
Website: http://www.seventreeswoodworking.com
I have a customer who is looking for what they call "patchwork construction" for some commercial bench seating and walls. I have a picture attached that shows the idea. I was thinking about how to do this on a larger scale than a piece of furniture. My first thought is to somehow laminate plywood with 1/8" thick resawn lumber, but I don't know how to keep the pieces together to get it into the vac bag- veneer tape? Masking tape and then run the sheets through the sander? Would veneer tape work on thicker boards? Would I have to balance this with 1/8" thick or could I just put veneer on the back?
After I have the plywood it would be simple to make the pieces like we would if it was plywood.
My other thought is to build the piece and then nail 1/4" thick solid wood t&g boards to the piece.
What do you guys think?
Thanks,
Jarin
View higher quality, full size image (640 X 426)
2/29/16       #2: Patchwork Plywood ...
D Brown
Looks a lot like laminate , maybe that's how to do it .
2/29/16       #3: Patchwork Plywood ...
1/8" is okay for the rough thickness, but you will have to sand it down to 3/32" or less to get it to act like veneer and not solid wood. Veneer tape should work, easy to experiment. I'm a firm believer in matching the faces for best balance. How or what would you use for edge banding? Looks to me like you will have to do that before the veneering process to keep the right look.
3/1/16       #4: Patchwork Plywood ...
Snaglpuss
Can't you find a veneer guy to lay this up for you.
This little voice in my head says trouble on the way if you use solids.
3/1/16       #5: Patchwork Plywood ...
Alan F.
They probally saw a picture of something like stinkwood.
Otherwise get a random match veneer panel made like the PDF.
DSCF4074.pdf
stikwood
3/1/16       #6: Patchwork Plywood ...
Mark
It looks as if someone took a picture of a floor and had it copied onto laminate.
To get it in wood veneer, I'd definitely call someone who lays up custom sheet goods. Might not be too cost prohibitive if all the sheets can be the same and you cut for randomness.
3/1/16       #7: Patchwork Plywood ...
Robert Member
There is a shop in San Francisco called Jeremiah Furniture Collection and they manufacture solid Furniture from random Walnut planks. This looks like one of their pieces or something very similar.
3/20/16       #8: Patchwork Plywood ...
Brad
Give the client the "furniture level" price of veneered surfaces and the "quick and dirty" T&G nailed on price.
For veneered, balance both side the same if it's a door. Trapped panels, use your own judgement.
I'd use regular thickness veneer to do this. If you can outsource to a veneer shop, even better.
If you really want to go nuts and do custom sawn veneers, use clear packing tape instead of veneer tape. Use a vacuum press. Wipe with acetone after it comes out. Works really well.
