Making internal softwood doors
4/28/16
sam myler Member
Hi
I was looking for some advice i was looking to build some internal doors out of (scott) red pine but i am worried about twisting further down the line. if they are clamped properly and sealed will they stand the test of time or is there any thing else i can do to prevent this happening
4/29/16       #2: Making internal softwood doors ...
Geoff
Mill your lumber to S4S and stack it on edge in a place that will have the same conditions as your house (temperature, humidity). Let it sit for a few days. Go back through the material and check for excessive bow or twist. You can deal with some bowed stiles by putting them on the hinge side or latch side if the stile will touch the top and bottom of the stop and flex in to the latch. A twisted stile is the death of a door. To check for twist place the stile on a flat surface. If the board rock from corner to corner on opposite end, don't use it.
4/29/16       #3: Making internal softwood doors ...
MarkB Member
I thought a twisted anything was a disaster for a door.
In my experience red pine is an utter nightmare. All the sitting/stacking/acclimating in the world won't save you if the stock isn't flawless to begin with.
4/29/16       #4: Making internal softwood doors ...
I would not know Red Pine if I tripped over a piece.
We use Sugar Pine for our millwork that requires Pine. Our vendor has C+btr as well as a couple of knotty grades. The stuff is very stable and a joy to work with. It is rare to see a piece move after jointing and planing.
I suggest you bring your pine in and acclimatize it, then face and edge on the joiner, leaving it oversize. Sticker it, and let it sit for a few days, then put the eye to it. If it is straight, then it is worth planing, but then let it sit again, and then take a look. Twisted will not work, but some bows can be acccomodated if you work with it a bit, as stated above.
I find that as a commercial enterprise, I just cannot take the risk, so I buy and use the best wood I can to minimize problems and smooth the process.
4/30/16       #5: Making internal softwood doors ...
Sam Myler Member
Thanks for all you're impute it is much apriciated. If the timber is correctly
Climitised and then the twisted ones removed can you foresee and issues further down the line when the doors are hung also would giving the doors a finish help. I have attached a picture of the doors I am wanting to make
4/6/17       #6: Making internal softwood doors ...
Johnson Amira Member
Website: https://www.emeralddoors.co.uk/
When it comes to residential furniture, wood has always been the first priority due to its salient features. Wooden furniture has been with the humanity since last century.
We've also published a well-researched infographic content on '10 Reasons Why Wood Is The Best Material For Doors in terms of Style & Security'. We've included few vital points such as security, soundproof, maintenance, installation. Here's the link to my content - https://www.emeralddoors.co.uk/wood-is-best-material-for-doors
