Entry Door Paint Grade
8/15/16
cabinetmaker
I am looking for 1 3/4" thick door 35 3/4 wide 82 7/8 tall. Nine light 8 1/2 x 12 3/4 tall each opening It will be paint grade, and I will prime with alkyd and 2 coats of semi gloss oil
Can anyone recommend a good shop ?
Need an estimate and lead time.
Please PM me
8/15/16       #2: Entry Door Paint Grade ...
RichardP
3 lite openings 8.5 wide would take up 25.5 of the door width and to that add some clearance. Most door stiles are 6" wide but the glass openings protrude into that 6" perhaps .5 or, more often more. Then you must allow for mullions between the glass openings. Do the math. The glass is too wide!
Rich
8/15/16       #3: Entry Door Paint Grade ...
cabinetmaker
Thanks for the heads up we can reduce the stiles a bit. Its a replacement door that has been on the house for 30 years.
8/15/16       #4: Entry Door Paint Grade ...
Dan/drbwoodworks
Where are you located ? We are in southern Ct. Would be interested in building, we can turn those out relatively quickly.
