Large window and door carry handles
10/16/17
Ive looked on-line and through the Uline catalog. Searched with several different criteria but wondering if anyone knows of a source for the black plastic screw on carry handles that often come screwed to the jambs of large doors and windows?
We have a slew of 11'long x 4' tall interior window units to build and several smaller 5x5 units and would like to send them out with handles on them.
10/16/17       #2: Large window and door carry handles ...
B.H. Davis Member
Here are a couple options. First one is non-throw away handles so cost could be an issue. Second one is throw away but not made for the weight limits you are talking.
You'll have to copy/paste the links into your address window.
McMaster-Carr for steel or plastic handles:
https://www.mcmaster.com/#standard-pull-handles/=19udefh
These won't be strong enough but perhaps can be a lead to something better:
http://www.allenfield.com/Product-categories/Standard-and-Heavy-Duty-Series/
BH
Davis
10/16/17       #3: Large window and door carry handles ...
Randy
I found some called lift handles
https://secureitfast.com/search?q=lift+handles
10/17/17       #4: Large window and door carry handles ...
nicko
I buy garage door handles. They are metal and inexpensive. They are for my own use so i typically remove them and re-use them when I'm done.
nicko
10/17/17       #5: Large window and door carry handles ...
Thanks guys. Randy nailed it. Ive used sheet metal garage door handles before but I won't be getting these back so 15 - 20 cents a piece is perfect.
I searched high and low. Need to hone my search skills.
Thanks again
