Table base
2/17/18
Mike Member
I have a table base to make. The table top will be 8'x8' (huge). The base must be 4'x4' and be about 29" high. The base will look as if two pyramids were joined at the 18" mark, bottom looking like a pyramid, top piece inverted. It would be as if the base had a "waist". What do you think?
2/17/18       #2: Table base ...
Show a drawing
2/17/18       #3: Table base ...
Base better be made out of steel plate and anchored to the floor.
2/18/18       #4: Table base ...
MarK B Member
Sounds like a pretty stable design to me and would allow you to get the waisted area fairly small. 4' square at the floor and 4' square at the under side of the table. Basically a large pedestal boxed-in to make the upright and inverted pyramid. The 2' overhang will help with keeping peoples feet off the base but probably not by much. The cavity in the base could easily be used to include some ballast if the construction was to be fairly light weight.
Given the a good amount of weight in the base and top it'd be tough to up-end the table with 6' of table on the base and a 2' overhang though Im sure it could be done if one end of the table were populated with a lot of weight and absolutely nothing on the opposing side.
This is a rough calculator Ive used in the past to give an idea on stability. https://www.gyrobases.com/gyro-table-stability-calculator/
2/18/18       #5: Table base ...
Pat Gilbert Member
Make sure it will fit INTO the room.
The design sounds ok to me. Maybe something clever to join the two pyramids. Also what are you going to do at the joints of the pyramid. I have made lots of pyramids but just used glue and tape, in this case you will need to use a clete screwed on the inside joint cut at the proper angle, i.e. it is not going to be 45 deg.
2/18/18       #6: Table base ...
Pat Gilbert Member
Check this out it might help you
This is useful for calculating angles
2/18/18       #7: Table base ...
We don't have any idea how wide the points of the pyramids will be at the waist. Base size is okay, but that is an 8' square top and if the mating point of the pyramids is too narrow, that's the trouble point. I'd never build an 8' square table on a single post in the center. As mentioned, 8' won't go through normal doorways.
2/19/18       #8: Table base ...
Pat Gilbert Member
At the waist the horizontal distance will 24"
2/19/18       #9: Table base ...
I'm asking about the cross section at the waist. The OP described the base as a pyramid, and an inverted pyramid on top of that. Technically, that describes the waist as a point, right? Maybe I'm not understanding the verbal description.
2/19/18       #10: Table base ...
et
Depends on the height of the pyramids. If they are equal and both the full 29" that would put the waist at 24" wide, but Mike mentioned a joint at 18" so I envision something with unequal pyramids like this?
View higher quality, full size image (1483 X 694)
2/20/18       #11: Table base ...
Pat Gilbert Member
My bad, I missed the 18" height. Based off of et's drawing it looks like 18" on the horizontal"
BTW et what software did you draw that in?
2/20/18       #12: Table base ...
MarkB Member
That was my thought of the scenario. If you built that base out of poorly joined ply each leg would act like a massive gusset. You could park a Sherman tank on that table if the base.was heavy.
Negativity abounds in this world.
Put a central 4" square post in that table, add eight gussets (legs of the. Pyramids) and you've got a table that could hold up the world.
But we need steel bolted to the floor.
2/21/18       #13: Table base ...
et
Pat , that was just a quick sketch in inventor
