SCM 746 grinder
5/7/18
Lynn Floyd
I recently purchased a SCM 746 profile grinder. I don't know how to tilt it for side clearance. There is a bristol lock on the shaft housing and a knife lock for various angles, 5, 10, 15? Do you rotate it by hand and lock it? I got a parts manual from SCM but they didn't have an operators manual. I don't want to force it.
5/8/18       #3: SCM 746 grinder ...
AM
Yep, just loosen the handle and use the knife lock to adjust. Tighten it back up. Should turn by hand, you may have some corrosion in the works. Link to manual below.
https://www.partspronto.com/MachineDocs/Foley%20Grinder.pdf
5/8/18       #4: SCM 746 grinder ...
Lynn Floyd
Thanks. That's what I thought.
3/30/19       #5: SCM 746 grinder ...
Rene Rosas
Anyone have an updated link to the manual for the SCMI 746 or Foley 75-12 profile grinder?
