Sliding table saw cutting curves
8/28/18
Hey all, I searched this but didn’t know what to search under.
I noticed that when I cut a sheet in half that the piece in the sliding side of the blade is straight, the piece on the table side of the blade has a slight curve in it. I was wondering what is causing this and if it can be fixed?
The saw seems to be all set up nicely. The saw is a SCM Nova.
8/28/18       #2: Sliding table saw cutting curves ...
Try a fresh blade first and see if that helps.
8/28/18       #3: Sliding table saw cutting curves ...
Karl E Brogger
What happens if you rip them both on the wagon again?
Most sheet stock carries some tension in it.
When I rip a sheet on my panel saw, often times there will be a gap in the field of the sheet and it's touching on the ends. If I rip the parts again, they fit tightly together.
8/28/18       #4: Sliding table saw cutting curves ...
Hen Bob Member
Karl has it correct, The sheet stock has tension especially when its hot and humid like the current weather. I see the same thing as well... I recall there being a discussion on here about a good cutting sequence on a slider to overcome it
8/29/18       #5: Sliding table saw cutting curves ...
door shop guy
I have cut lots of melamine on a tablesaw 8-20 years ago and never had problems then out of nowhere had problems a lot with banana cuts. My thought is that something changed in the material or the way they product the melamine. Now i dont deal with melamine at all and i do not miss it one bit.
