Identify molding
9/23/21
LU
HI,
Could anyone help identify the large molding in the middle of the mantel?
Thanks!
View higher quality, full size image (828 X 1232)
9/24/21       #2: Identify molding ...
Russ
Website: http://www.mr-moulding-knives.com
Hello
Would you be able to provide a little more information on this piece; width, thickness?
The fireplace surround could be a stacked profile consisting of two or more pieces of moulding.
You may try looking in our moulding catalog under, Chair Rail, Trim, or Casing. Sorry, we don't have a category for fireplace surrounds.
Good luck
All the best
Russ @ MR
9/24/21       #3: Identify molding ...
TonyF
LU:
I have not seen a molding profile like the one pictured. To me, it looks like three seperate moldings under the crown molding frieze. If I had to guess, and wanted to come close with stock moldings, I would say that the larger ogee piece is a modified SM-59 "Strawberry Hill" molding with the bottom beads cut off, on top of which is a panel/picture frame molding of uncertain profile, and on top, directly under the frieze, is a small stepped bullnose or shallow ogee edge, it is hard to tell from that photo. I am guessing the molding scale based on its relative size to the fireplace opening setback requirements.
You could come close with stock moldings, if you need to replicate the look elsewhere, but if you need an exact match that will withstand scrutiny, start grinding some cutters.
Hope this helps. Good luck.
TonyF
9/24/21       #4: Identify molding ...
Keeping in mind this is a typical custom one off mantle. Its not I'm guessing that its a 4-5" wide section. That would be a very deep cut to make with one cutter.
There are three pieces. The lower section which was made out of a big chunk of wood. Two profiles on the shaper. The deep top cut and a typical round over cut on the bottom. Then they were planed/sanded to look good.
The upper section is some little profile mold with a stretched quarter round/shoe applied above it.
9/24/21       #5: Identify molding ...
Looks custom to me.
10/14/21       #6: Identify molding ...
D conti
It looks like a bar rail molding applied vertically. That is a stock molding wrapping it. Generally most mantels are made with stock moldings unless the mill shop has a molder or access to custom profiles.
