Subject: Re: Label printer that can interface with Spreadsheet
1/6/23
Redfish Matt Member
Over in our assembly and packaging area we are looking for software (Windows based) that can take data from a spreadsheet and produce labels on a roll-style label printer. The data sheet already exists are part of our manufacturing process and provides all the info we need on these labels.
I need this to be as simple as possible on the end-user. I don't want them to have to map out all the matching and formatting to get the spreadsheet columns with text boxes.
I need them to be able to open the spreadsheet on the Label software and start printing labels, one at a time, as needed. Similar to how you see on CNC routers with Label-It software tied in with Cabinet Vision.
I can kinda do this with the Avery Design And Print downloadable software but I have to personally map out every individual job, and the labels are printed on sheets.
I need to be able to set ONE label template and use it to pull data from the data files stored on the PC, so that the end-user out in the shop doesn't need to be skilled at label creation. Just open the software, select the file, and start printing.
The label size isn't critical, anything roughly 3x4 or 3x5 will suffice.
Can anyone suggest a label software and printer? This is outside my own usual expertise.
1/8/23       #3: Label printer that can interface wi ...
Derrek
We use the Avery label and print from excel. We have template in excel that we built to fit label and cells are populated. We have Avery labelmaker selected as printer
1/9/23       #4: Label printer that can interface wi ...
Redfish Matt Member
Derrek thank you-- are you using a standard 8.5x11 sheet of labels or are you using a dedicated roll-type label printer?
1/9/23       #5: Label printer that can interface wi ...
Derrek
Dedicated roll printer
See video below on that type.
For what it’s worth I fought buying LabelIt for years from CV. If your using CV, just go buy it it’s so much easier and cheaper in the last big run than trying to figure out how to do a workaround.
Link is to our demo set up I have several other videos you can search on label it printers and labels as well
Label set up
1/9/23       #6: Label printer that can interface wi ...
Redfish Matt Member
Thanks, I'll look at the video in the morning, I appreciate it!
And yes we actually do use Label-It at our CNC. The labels I'm discussing in this thread are for something else in the shop. Essentially just packing labels, not too unlike what comes off of Label-It, just formatted differently, and lacking the part image.
4/18/23       #7: Label printer that can interface wi ...
vadry
The Avery Design And Print downloadable software helps somewhat, but I still need to plan out each project beforehand, and the labels come pre-printed on sheets.
    • Better Vacuum Cups, Inc.
    • INNERGY
    • Texas Woodworking Festival
    • Air Handling Systems
    • TradeJobPlacement.com
