Subject: Re: Edgebander restarts
Edgebander restarts
2/15/24
Oliver Simpson
Hi I operate an Optimat KAR 310 Homag edgebander. Does anyone know why the computer would auto restart when edging the ends of long panels? It only seems to do it at these times. When the computer restarts the machine continues running. Thing is, you can't just login again as the machine is already referenced so you have to isolate the machine and turn it on again. Any help would be greatly appreciated. We have already had an engineer out and he doesn't know why it's doing it.
2/15/24       #3: Edgebander restarts ...
Brian
In my experience it has always been a computer related issue, usually random somewhat frequent restarts are power supply related at least that is the first place I look. While the application running on the computer may get feedback from the machine it would be a stretch for machine feedback to get so far as to trigger a restart. Voltage errors from the power supply, usually low voltage can and will do this. Power supplies are not expensive and are easy to replace, it might be that the power supply is full of dust and getting to warm, I have seen that on occasion as well.
2/15/24       #4: Edgebander restarts ...
Rich  Member
I am not familiar with Homag banders, but we had a similar issue where there was a wire that had worn threw insulation when pivoting the display.
2/27/24       #5: Edgebander restarts ...
hopkins Member
What are some common causes for random frequent restarts in computers, and why is the power supply often considered as the first place to look when troubleshooting such issues?
    • Impact Search and Placement
    • Air Handling Systems
    • Better Vacuum Cups, Inc.
    • TradeJobPlacement.com
    • INNERGY
