Subject: Re: Covering a window with a cabinet?
12/16/15
Mike Fuson
I have a client that wants to cover a window up in the kitchen with pantries. Basically she wants to shut the blinds in the window so that it looks normal from the outside but the inside will have the cabinets over the window. Her only question was would there be any moisture issues in the window? It is a double payne type window. Any thoughts?
12/16/15       #2: Covering a window with a cabinet? ...
dan
It depends how cold it gets outside where the house is
we have covered over windows before
first we use a rigid foam tight cut into the window jambs and then we use a silicone to seal it air tight as if to create a vapour barrier
this has worked for us with no call backs.
12/16/15       #3: Covering a window with a cabinet? ...
Mitch Suber  Member
Website: subercustomshutters.com
On more than one occasion, I have been ask to install blinds or shutters, into these situations. Some have had cabinets in place, in front of the windows for years, some had just been installed. I have never noticed any moisture issues, but I will say the cabinets do handicap us being able to do a quality installation. A few have just about been impossible. Usually the main issue is the customer wants all the windows treated the same, so they have a consistent appearance from the outside of the house, especially on the front. Something that was not considered, or considered important, when the cabinets were put in. I will say these windows become dust traps, and along with any shutters or blinds, they are difficult to keep clean.
12/16/15       #4: Covering a window with a cabinet? ...
Matt Calnen
The last shop I worked at we did just such a thing on the second floor. We painted the back of the cabinet flat black to make it less noticeable from the outside. Guess what happened? We inadvertently made a greenhouse an it heated the window up so much it blew it's seals out. I would say it would be good to let it breathe.
