Subject: Re: Cabinets doors binding at hinges
1/1/16
jonmcay
I refinished a corner cupboard for a customer. It was in rough shape when I got it since it's previous home was in a barn. I did the repairs and finished it The top cabinet doors bind at the hinges when they about inch or so before they close. The hinges don't look bent. I sanded the edges of the doors. I even put cardboard shims in the hinges mortises to see if they were too deep. Any help would be appreciated . Thanks
1/1/16       #2: Cabinets doors binding at hinges ...
Mitch Suber  Member
Website: subercustomshutters.com
I sometimes have hinges bind on shutters during installations. Whether you are dealing with two or three hinges, the barrels should all be in alignment to prevent binding. Sometimes it is possible to find the culprit, by removing the attachment screws completely from one hinge at a time. Leave the hinge attached to the door, remove the hinge screws securing it to the cabinet. By holding the door in one hand, and holding the hinge against the cabinet with the other, swing the door, Move the loose hinge around some, trying to find a position where it does not bind. Also, this is a good time to see if the hinge even works properly. Often the pins may rust, or become filthy, which makes them feel like they are binding. A loose pin hinge can be cleaned by removing the pin. Buff it if needed, oil it as well. Also check the pin, a bent pin is another problem that causes binding.
Once done with this hinge, repeat for the others.
