Subject: Re: Hoffman dovetail routing machine
3/20/16
Dan/drbwoodworks
Are any of you guys using one of the Many Hoffman dovetail routing machines for your face frames ? What are benefits you have seen over pocket screws ? Thanks
3/21/16       #2: Hoffman dovetail routing machine ...
Bad idea in that you have to cut both sides to receive the keys and you have to figure out how to index the cuts.
The only reason this makes some sense is to do a beaded inset frame. The only reason would be the creep you get from pocket screws. This is more sales rhetoric from Hoffman than reality though.
Hoffmans are good for other things but not face frames.
3/21/16       #3: Hoffman dovetail routing machine ...
We've had one for many years, great machines. As for indexing face frame parts, they make rail extensions and assorted stops or you could install other stop systems. We haven't made a face frame in 25 years, but the machine still gets a lot of use.
3/21/16       #4: Hoffman dovetail routing machine ...
JR Rutter Member
I only use mine for mitered frames. It excels for that use.
3/21/16       #5: Hoffman dovetail routing machine ...
Dan/drbwoodworks
We are using castle pocket hole machines , Tsm-21 , I believe . Much better than the Kreg machines . We are going through some growing pains and I'm looking at all the ways we do things and trying to figure out if we can same time anywhere ,I think I will still get a Hoffman dovetail machine for the multitude of other things we build
