Subject: Re: Dual cold bond adhesive
2/24/17
A Facebook friend had a refacing company come out and give her an estimate.
They said they don't use contact to apply the glue, rather they called it a (Dual
Cold Rolled Adhesive). Is that not the peel and stick? Similar to FastCap's speed tape?
Have any of u used this (adhesive), especially on cabinets in a kitchen that already have a finish on it? I know you have to, at a minimum, remove the gloss and suff the surface, if not strip the finish
From what I saw and have learned, even if you pre-finish the veneer, if you put too much finish on it, it's likely to pull away from the adhesive
