Subject: Re: Wood range hood venting
5/4/17
Tony
Hey Guys. I'm working on a design for a kitchen remodel. They want a large wood range hood surround that will go all the way to the ceiling. The problem is venting. There is no way to get a blower vented outside in this particular situation. The only solution I have been able to come up with is to use a ventless blower with filters, and vent back into the room via a wood grill of some sort. We have done this before, but the customer is really against he idea of the wood grill showing.
Just wondering if/how you have addressed this situation. Thank you for any suggestions.
5/4/17       #2: Wood range hood venting ...
Bill STANISCI
One alternative is to go into the ceiling a short way and vent from the ceiling with a steel/painted vent.
A second alternative is to keep the hood from the ceiling and put an elbow with a 9 x 3 or similar elbow to blow the air back into the room out the front. Depending on the room and the angles you might not be able to see the elbow.
A range hood that does not blow out is marginal. It should have a filter that contains charcoal to absorb the smells. Most recirculating kits have these filters. Recirculating filters need to be replaced periodically.
Good luck.
5/4/17       #3: Wood range hood venting ...
As far as I am concerned, a range hood that does not vent outside is useless. You don't get rid of all the humidity, and no one services the filters well enough that sooner or latter you have a grease problem. Can you run the vent into the stud cavity and then outside under the floor?
5/4/17       #4: Wood range hood venting ...
I should have said into a duct in the stud cavity.
5/8/17       #5: Wood range hood venting ...
Mike Fuson
Another option on venting outside is to run it through the ceiling and through the joist above horizontal and out the eve. I know that's not what you're asking but I agree with rich about ventless. The last few years I've just told people that they have to be vented out, plain and simple.
