Subject: Re: Adjustable shelves w/ tall nosing
9/3/17
Paul
Hello.
I was wondering if there is a formula for adjustable shelf length compared to carcass length, including nosing?
Im about to make some cabinets with 2.5" nosing. What should i deduct from the measurement to ensure the shelves can be removed without touching the sides?
9/3/17       #3: Adjustable shelves w/ tall nosing ...
Bob
If you use the formula A squared + B squared = C squared where A is the nosing width, B is the carcass width, C will be the diagonal length of the shelf edging. A shelf for a 30"wide carcass would need to be about 1/8" shorter. The wider that the carcass is, the less you will have to shorten the shelves.
9/3/17       #4: Adjustable shelves w/ tall nosing ...
Mike Fuson
What Bob said, but if it's a face frame type cabinet where the ends don't show then I cut the molding shorter than the shelf because it don't show. If it's a frameless situation then the shelf can be pulled out and be slid back in in a different place so I cut it the same as the shelf.
9/5/17       #5: Adjustable shelves w/ tall nosing ...
Mark  Member
I'd cut one and try it.
