Subject: Re: Dowel drill adapter
Dowel drill adapter
9/11/19
Good morning.
Anyone know where I can get an adapter to put a normal drill bit into a 10mm dowel drill socket?
All the adapters that I see online are the other way round.
9/11/19       #2: Dowel drill adapter ...
Bill Member
Vortex had adapters from 10mm to between 2 and 5 mm.
They can't be easily found online. I would call them.
9/11/19       #3: Dowel drill adapter ...
Bruce H
Depending on what size there are split collars that fit into a 10mm hole and are drilled for standard twist drills. Mine are small, 2mm & 3mm. I made one using a broken 10mm bit, drilled it out for 13/64 and used a set screw to keep it in.
9/12/19       #4: Dowel drill adapter ...
Chuck Hicks Member
We can help with some sizes.
View higher quality, full size image (1410 X 428)
9/16/19       #5: Dowel drill adapter ...
Larry Schweitzer Member
Check European Tooling Systems, ETS, online catalog.
